Netsight - Device temperature
‎03-10-2017 10:55 AM
Does anybody know if it's possible to show the device temperature in celsius when generating a report in Extreme Management?
When looking at the device in DeviceView it shows the current temperature "correctly" in celsius, but when I generate a report under "reports -> custom report" selecting "device -> device temperature" the y-axis is in fahrenheit.
4 REPLIES 4
‎06-12-2018 12:09 PM
Thank you! in Canada here, and looking for that as well  Thanks,
‎05-17-2017 02:45 PM
Hello,
I have created a new request with engineering to see if they can get this feature added to a future version of software.
‎03-22-2017 03:09 PM
Hi Bastian,
The temperature shown in Fahrenheit from the report corresponds correctly to the Celsius value shown in deviceview. As you suggest this is possibly a matter of generating a new device temperature report which presents the data in Celsius instead of Fahrenheit?
I believe most of the network administrators in Europe always likes to see the temperature in Celsius 
‎03-21-2017 06:14 PM
Hello Knut,
can you confirm the Temperature in Fahrenheit is the calculated correct / displayed Temperature in Celsius. If thats the case, the AXIS if correct. In case if you asking if we can see all in Celsius or Fahrenheit. we need to build an new report. What would you like to see.
regards
BAstian
regards
BAstian
