Netsight Palo-Alto integration guide
Justsomebodi
New Contributor III
Does anyone know what happened to the guide?
8 REPLIES 8
Krzysztof,
If you have 8.0 installed, the info is in the Contextual Help, in https://[i
Here's a document detailing the same info for Extreme Connect v3: https://app.box.com/s/ritf9yfb5ldd39wztx1tzevy4007159w
Hope this helps.
Is there any documentation for Palo Alto plugin built in Extreme Management Center v7.0? Fields there, are different then in documentation for previous version in this link: https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=a399e9c2-5f8f-4333-a70e-b9302...
The API is included in Extreme Management Center v7.0.
For previous releases, you must download and install a plugin that is kind of hidden. You can find it in the Extranet under SDK Connect:
https://extranet.extremenetworks.com/downloads/Pages/OneFabricConnect.aspx
There, under the Partner Resources tab you will find several different versions of the plugin. Which one to use depends on the release of NetSight (now known as Extreme Management Center)
How i download ONEFABRIC CONNECT ?
