‎02-12-2020 10:20 AM
Hello anybody,
After installing all functions, Switch is not inserted into EMC. After reboot of the Cent-OS host the switch is visible.
Where is my error? What can I do?
Greeting
‎03-12-2020 10:59 AM
Hi Zdenek,
Sorry for the late reply, but that didn't help.
Also I can only delete switches from Access Control but not from Network. In the Java Console this works…, the same reason?
Bernd
‎02-19-2020 09:13 AM
After adding the switch to XMC the XMC tries to perform full discovery. on some devices, it may take several minutes.
If you know the device is very slow on SNMP then you add the device as ICMP and then change the profile. the discovery will run in the background but you will see the device on your list.
