NMS-ADV and EAC/Application Analytics virtual instances limit
‎11-23-2016 01:50 PM
Hello,
what is the actual limit of EAC virtual instances and Application Analytics virtual instances that can be installed after buying single NMS-ADV license?
Kind regards,
Tomasz
Kind regards,
Tomasz
8 REPLIES 8
‎11-23-2016 02:09 PM
Ok, thank you. I might have introduced too much noise here maybe because of my English. So I can tell the VAR he can just deploy another virtual appliance with no additional cost.
Many thanks,
Tomasz
Many thanks,
Tomasz
The current maximum is 6 Analytics appliances, and 3M flows total for the total Extreme Management Center (Netsight) system.
see also
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-many-Purview-appliances-can-I-add-in-my-N...
see also
Ok, as many EAC appliances as one'd like (w.r.t. EMC management limit). Does this also apply to Application Analytics appliances? I couldn't spot this in the docs.
Regards,
Tomasz
Regards,
Tomasz
Hi Mike,
to be more clear - when one buys NMS-ADV-XX, he's entitled to install virtual NACs and virtual Application Analytics engines, right?
But how big this entitlement is - limited to 1 Application Analytics engine or not?
The customer would like to add some distant building to his Extreme Management Center with EAC and Application Analytics coverage as well.
Kind regards,
Tomasz
Kind regards,
Tomasz
