Not possible to take archives from my devices
Sacha_Brys
Contributor
I have a failure on every switch:
Failure: 100%
reason: Management Center Archive - Error Archiving Configuration File.
See screenshot.
Trying to create backups from my configurations on my switches, but this is not working.
7 REPLIES 7
SDR
New Contributor III
Hello,
is there any solution for that?
I´m also getting “Failed to open SFTP connection.” while trying to archiv en ERS4950, running 7.8.2.027 to XMC 8.5.2.6
BR
Jasper_R
Looks like a switch issue. Got an ERS49xx running 7.6.0 and XMC 8.1.3 … “Failed to open SFTP connection.”
Tried copying config to my PC running an SFTP server, same error.
Tried connecting to my pc running an SFTP server FROM another PC: works.
David_Choi
Hm.. Please check if there is any difference between working and non-working switches.
And in addition, I could not find any information about ERS products in the XMC release-note of version 8.1.3.65 (even though the backup configuration is general script operation).
When you refer following link, the XMC version which tested with ERS series is 8.2 and also the ERS 4850 version is 5.12 and 5.13
https://emc.extremenetworks.com/content/common/releasenotes/extended_firmware_support_8.2.htm
Best Regards,
Sacha_Brys
Contributor
Hi, thanks this helped a lot.
Allthough still a few switches do give me the error message:
These switches have the same model and firmware.
Do switches need to have a specific config?
Where are those configuration files located on the XMC?
