nstftpd verbose syslog output
StephanH
Valued Contributor III
Hello,
is there a option to enable an verbose output to syslog for the nstftpd (= XMC internal TFTP).
I see only syslog entries for failed connection (two lines: one => who/what's done and one with error message).
But I need the information for all IPs downloading a file successful.
Best regards
Stephan
Regards Stephan
1 REPLY 1
StephanH
Unfortunately no answer, but I have a workaround 😉
Now I am using the tftp server from the Infoblox IPAM and that tftp server send me the information I need (filename and IP of the requester) to the syslog server in XMC
Regards
Stephan
Regards Stephan
