Open XMC web gui on IOS device
ken4
New Contributor II
Hello, I opened XMC web gui on IOS devices throught Chrome and Safari browser, but it shows "Connectiion to server lost. Please try again later". Please advise how to fix it. Thanks.
1 ACCEPTED SOLUTION
Zdeněk_Pala
QA has identified this as a certificate related issue.
iOS versions 10.3 and higher don’t trust root certificates that aren’t already pre-loaded in their certificate store. It does not appear that there is any way to allow non-trusted certificates (as you can do via Mac OSx).
Unless you’ve replaced your server certificate with one from a trusted root authority this issue will exist.
https://support.apple.com/en-us/HT209144
The workaround for customers who want to use XMC on iOS devices is to purchase and install a valid certificate from one of the Trusted Root CAs .
There is a GTAC article on how to generate a CSR on an XMC server to send to the CA and also how to install the retrieved Cert from them here:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-generate-a-CSR-Certificate-Signing-...
Hope it helps.
Z.
Regards Zdeněk Pala
2 REPLIES 2
ken4
New Contributor II
Thanks, I fixed it by installing server certificate in XMC.
Zdeněk_Pala
Hope it helps.
Z.
Regards Zdeněk Pala
