Why would Console and Policy Mngr differ when viewing the default port policy role that is being applied. Policy Mngr is showing in one case 20 ports with a specific role and Console only shows the role on 10 of those ports
Enterasys has confirmed that they are aware of this issue. I am running Netsight 5.1 and Netsight ver.6.1 is in the works with a fix. Screen shots are available in the case 01021283. Clarification... When viewing Netsight Console the "BasicPolicy" tab all the ports set to have a specific default role do not show the role, under the "Default Role" column. If I SSH to the switch (C3) and do a "show config policy" the "set policy port xx.x x is there for every port intended. The Netsight Policy Mngr. also shows all the intended ports for the role when I select a role and under the "ports" tab do a retrieve operation.
