Purview Flow CSV Export not working because of LineFeed in Row
Michael_Kirchne
Contributor
The Flow view in Purview allows to export the Data to CSV. Unfortunately the CSV can not be imported into e.g. Excel properly because the "OrderedMetaData" column inlcued the ASCII Line Feed Character (0x0A)
Hex View
b32555f687e748bd80ab50425e4fcd81_RackMultipart20150413-29298-1bn8bae-csv_2_inline.jpg
In my opinion this is a bug unless somebody knows how to import a csv ignoring the LF in this column.
Best Regards
Michael
2 REPLIES 2
Michael_Kirchne
Contributor
It is 6.2.0.199
Frank_Thomas
Which version of Netsight/Purview are you using?
