Purview Flow CSV Export not working because of LineFeed in Row
‎04-13-2015 08:21 AM
The Flow view in Purview allows to export the Data to CSV. Unfortunately the CSV can not be imported into e.g. Excel properly because the "OrderedMetaData" column inlcued the ASCII Line Feed Character (0x0A)
Hex View
In my opinion this is a bug unless somebody knows how to import a csv ignoring the LF in this column.
Best Regards
Michael
Hex View
Best Regards
Michael
2 REPLIES 2
‎04-16-2015 03:01 PM
It is 6.2.0.199
‎04-16-2015 01:37 PM
Which version of Netsight/Purview are you using?
