Ridgline 4.0 SP2 when add switch timeout.
Tavares_Belmont
New Contributor II
Hello guys!
After upgrade Ridgline SP1 to SP2 i tryed remove and add again one switch stack, but i cant add again, i tryed too follow gtac information bellow:
https://extremeportal.force.com/ExtrArticleDetail?an=000078168
https://extremeportal.force.com/ExtrArticleDetail?an=000078006
But i continue with this problem can someone help me? (see the picture and switch configuration)
ExtremeXOS
Copyright (C) 1996-2015 Extreme Networks. All rights reserved.
This product is protected by one or more US patents listed at http://www.extremenetworks.com/patents along with their foreign counterparts.
Press the or '?' key at any time for completions.
Remember to save your configuration changes.
Slot-1 ADM.1 # sho
[KSlot-1 ADM.1 # show con
[KSlot-1 ADM.1 # show configuration | inc
[KSlot-1 ADM.1 # show configuration | include snmpMaster configuration
# Module snmpMaster configuration.
configure snmpv3 delete community "private"
configure snmpv3 delete community "public"
configure snmpv3 add group "v1v2cNotifyGroup" user "v1v2cNotifyUser1" sec-model snmpv2c
configure snmpv3 add group "v1v2cNotifyGroup" user "v1v2cNotifyUser2" sec-model snmpv2c
configure snmpv3 add community "3gb@t!" name "3gb@t!" user "v1v2c_ro"
configure snmpv3 add community "3gb@t!rw" name "3gb@t!rw" user "v1v2c_rw"
configure snmpv3 add community "v1v2cNotifyComm1" name "ST.173146567.10550" user "v1v2cNotifyUser1"
configure snmpv3 add community "v1v2cNotifyComm2" name "ST.173146567.10550" user "v1v2cNotifyUser2"
configure snmpv3 add target-addr "v1v2cNotifyTAddr1" param "v1v2cNotifyParam1" ipaddress 10.82.1.199 transport-port 10550 from 10.82.1.254 tag-list "defaultNotify"
configure snmpv3 add target-params "v1v2NotifyParam1" user "v1v2NotifyUser1" mp-model snmpv2c sec-model snmpv2c sec-level noauth
configure snmpv3 add target-params "v1v2cNotifyParam1" user "v1v2cNotifyUser2" mp-model snmpv2c sec-model snmpv2c sec-level noauth
configure snmp add notification-log default
Slot-1 ADM.2 #
[KSlot-1 ADM.2 # show snmpv3 community
Community Index : 3gb@t!
Community Name : 3gb@t!
Security Name : v1v2c_ro
Context EngineID : 80:00:07:7c:03:02:04:96:97:86:22
Context Name :
Transport Tag :
Storage Type : NonVolatile
Row Status : Active
Community Index : 3gb@t!rw
Community Name : 3gb@t!rw
Security Name : v1v2c_rw
Context Name :
Transport Tag :
Row Status : Active
Community Index : v1v2cNotifyComm1
Community Name : ST.173146567.10550
Security Name : v1v2cNotifyUser1
[7mPress to continue or to quit: [m [60;D [KContext Name :
Transport Tag :
Row Status : Active
Community Index : v1v2cNotifyComm2
Security Name : v1v2cNotifyUser2
Context Name :
Transport Tag :
Row Status : Active
Total num. of entries in snmpCommunityTable : 4
Slot-1 ADM.3 #
Slot-1 ADM.3 # sho
[KSlot-1 ADM.3 # show snmp
snmp SNMP
snmpv3 SNMPv3
[KSlot-1 ADM.3 # show snmpv
[KSlot-1 ADM.3 # show snmpv3 ?
access Access
community Community
context Context
counters Counters
engine-info Engine Information
extreme-target-addr-ext Extreme Target Addr Ext Table
filter Filter Table
filter-profile Filter Profile Table
group Group
mib-view View
notify Notify
target-addr Target Addr Table
target-params Target Params Table
user User Name
[KSlot-1 ADM.3 # show snmpv3 ac
[KSlot-1 ADM.3 # show snmpv3 access
Group Name : admin
Context Prefix :
Security Model : USM
Security Level : Authentication Privacy
Context Match : Exact
Read View : defaultAdminView
Write View : defaultAdminView
Notify View : defaultNotifyView
Row Status : Active
Group Name : initial
Context Prefix :
Security Level : No-Authentication No-Privacy
Read View : defaultUserView
Write View :
Row Status : Active
[7mPress to continue or to quit: [m [60;D [KGroup Name : initial
Context Prefix :
Security Level : Authentication No-Privacy
Write View : defaultUserView
Row Status : Active
Group Name : v1v2c_ro
Context Prefix :
Security Model : snmpv1
Write View :
Row Status : Active
[7mPress to continue or to quit: [m [60;D [KContext Prefix :
Security Model : snmpv2c
Write View :
Row Status : Active
Group Name : v1v2c_rw
Context Prefix :
Row Status : Active
Context Prefix :
[7mPress to continue or to quit: [m [60;D [KSecurity Model : snmpv2c
Row Status : Active
Group Name : v1v2cNotifyGroup
Context Prefix :
Read View :
Write View :
Row Status : Active
Context Prefix :
[7mPress to continue or to quit: [m [60;D [KSecurity Level : No-Authentication No-Privacy
Read View :
Write View :
Row Status : Active
Total num. of entries in vacmAccessTable : 9
Slot-1 ADM.4 #
Slot-1 ADM.4 #
[KSlot-1 ADM.4 # show configuration
# Module devmgr configuration.
configure snmp sysName "ADM"
configure snmp sysContact "[email protected], +1 888 257 3000"
configure timezone -180
configure slot 1 module X440-24t
configure sys-recovery-level slot 1 reset
configure slot 2 module X440-24t
configure sys-recovery-level slot 2 reset
configure slot 3 module X440-24t
configure sys-recovery-level slot 3 reset
configure slot 4 module X440-24p
configure sys-recovery-level slot 4 reset
configure slot 5 module X440-48t
configure sys-recovery-level slot 5 reset
# Module xmlc configuration.
create xml-notification target ridgeline_10.82.1.199 url http://10.82.1.199:8080/xos/webservice vr VR-Mgmt
configure xml-notification target ridgeline_10.82.1.199 user admin encrypted-auth YWRtaW46ZXBpY2VudGVy
enable xml-notification ridgeline_10.82.1.199
configure xml-notification target ridgeline_10.82.1.199 add idMgr
5df2b8f85841482c93825602bd59b94f_RackMultipart20150707-12764-1erihur-snmp_config_inline.png
11 REPLIES 11
Tavares_Belmont
New Contributor II
Of course Ram! I tried but the problem continue, thanks for your advice.
Ram3
Could you please execute the command "configure snmp compatibility ip-fragmentation allow" and try to add the device?
Ty_Izzet
Once you are able to get a packet capture of the process, would you open a case with GTAC and upload the capture to the case. I will review the capture once it is available. Let me know if there are any questions on this.
Tavares_Belmont
New Contributor II
Thanks,
Option 1 and 3 i had tried before but the option 2 i can't do it, because this switch is a default gateway that network.
Ty_Izzet
Tavares, the following can also be done:
1. please test with adding the switch using SNMPv2, v2c, and v3. This will help isolate any SNMP configuration issues.
2. Try adding the switch with a different IP other than the one used before. This is dependent if another IP address is configured on the switch.
3. Restart the snmpSubagent and snmpMaster processes on the switch. This may be necessary if no SNMP packets are being sent by the switch which the packet capture will help confirm.
Let us know the outcome.
