RTLS (Real-time Location System) on ExtremeNetworks Wireless Controller
PIYAPONG_YWR
New Contributor II
I have a Project that's need to use RTLS (Real-time Location System) to identify and track the location of assets, I understand RTLS had in WM3600, WM3700 but It's EoS now. And I'm not sure with C5210 can do RTLS? or it has function same like RTLS? or NetSight can do?
Thank you,
2 REPLIES 2
PIYAPONG_YWR
New Contributor II
Hi, Pala
Thank you for answer
And NMS can support RFID or not ?
Thank you,
Zdeněk_Pala
Hi. There are two options AFAIK: Use Ekahau or Aeroscout with combination of our wireless. Use NMS-advanced. NMS-adv can visualize some client location (one client at time). Controller can export the location information to external systems. Maps needs to be created by NMS-advanced. Best regards Zdenek
Regards Zdeněk Pala
