Site Engine 25.08.11.12 is Now Available!
Zdeněk_Pala
The ExtremeCloud IQ – Site Engine version 25.08.11.12 is available to download at Extreme Portal
You can find the release notes here.
The downloadable files can be found on the Extreme Portal, under Products:
Regards Zdeněk Pala
2 REPLIES 2
Zdeněk_Pala
The release 25.08.13.02 is now available for download at Extreme Portal.
If you are running 25.08.10 or 25.08.11 and you are not using L3 policy rules, then you can stay or upgrade. You will benefit from OS security patches after upgrading to 25.08.13.02.
If you are running 25.08.12 and you are not using L3 policy rules, then you can stay. There is no benefit to upgrading to 25.08.13.02 for you.
If you are using L3 policy rules, then we recommend upgrading to version 25.08.13.02 and re-importing your policy domain configuration.
Thank you
Regards Zdeněk Pala
Zdeněk_Pala
Dear community.
We will be removing this version of Site Engine from the Extreme Portal very soon due to an issue with Policy Manager rules and services. We will be releasing a patch version 25.08.13 very soon.
25.08.13 will have all patches and features of 25.08.10, and 25.08.11 and 25.08.12.
More details about the reason: https://extreme-networks.my.site.com/ExtrArticleDetail?an=000130748. Additional information will be shared.
We apologize for the inconvenience. GTAC has already procedure to help existing customers who are affected. If you are not affected, then there is no need for any action.
Thank you for your cooperation and understanding.
Regards Zdeněk Pala
