yesterday - last edited yesterday
When we add a new device to XIQ-SE, I would like it to automatically get a "device mapping" of what operators can see it or what operators cannot according to its site its placed in and a particular operator authorization group. I remember seeing a thread where @Zdeněk_Pala gave a sql query to run in the shell.
cd /usr/local/Extreme_Networks/NetSight/scripts/
./mysql.sh
use netsight
select nsdevices.ip, nsusergroups.groupname,nsprofiles.profilename from nsgrouptoprofile inner join nsusergroups on nsgrouptoprofile.GROUPID = nsusergroups.GROUPID INNER JOIN nsdevices on nsdevices.DeviceID = nsgrouptoprofile.DeviceID inner join nsprofiles on nsgrouptoprofile.profileid = nsprofiles.profileid;
I am not familiar with writing sql but could we modify the above query to modify a certain IP address and change the values of the group and the profile?
I am asking because it does not seem that "Device mapping" matrix values are available in the NBI to manipulate with a workflow.
With the above ask to insert in the sql database I think I could get python to execute that,. I just don't know sql at all. Thanks
13 hours ago - last edited 13 hours ago
Hi.
Adjusting values in th SQL database manually is not recommended and unsupported. Be careful if you go that path.
The GraphQL mutation can change the device's admin profile. I do not believe we have API call to change the device mapping: Device-UserGroup-DeviceProfile
9 hours ago - last edited 9 hours ago
Thanks. Could this API call be added as a new feature in an upcoming release?
