‎02-17-2025 11:42 AM
Hello,
I needed to migrate a customer to XIQ-SE 24.07 and just upgraded to 24.10. In both of them firmware upgrades transfers are extremelly slow. I haven't seen any log leading to a diagnose. For instance summit_arm-32.7.1.9-patch1-49.xos (110M) takes about 20-30 minutes to download to a 5320. I tried exactly the same download with scp from the switch cli to the tmp filesystem and it takes 20secs.
Is there any way to improve the performance of downloads? Or where I can look for any indication about what is not ok in the setup?
thanks in advance
Salva
Solved! Go to Solution.
‎02-18-2025 05:39 AM
Please open a support case if you wish to pursue this further.
The issue could be with CLI prompt detection. The SCP file transfer could be stalling. There could be any number of reasons why you are seeing what you are reporting.
‎02-19-2025 04:17 AM
Thanks Robert, will do
