Summit x350-48t reset to default
hoeper
Hi all! I bought a Summit X350-48t switch off of ebay and when I went to the terminal in puTTy and I put in the default login and it said that it was incorrect and I tried this several times. How do I reset the switch to factory defaults?
version:1.0.3.5
9 REPLIES 9
Thank You!
type boot, hit enter, then hold space again at the prompt. The 350 has a bootstrap and a bootrom. bootrom is where you enter the "config none" command
But still no luck
