Switches lose connection to ExtremeControl 7.0 .4.29 (TAFKAN) while performing DB backup
MartinS1
Hi there,
last week we decided to upgrade to NetSight Version 7.0.4.29. šŸ˜„
Since then, every time the NetSight DB is backuped, all switches appear as "Device Down" for a short period of time. But long enough for the system to send out the e-mail alarms.
As we've got 900+ Switches descovered, there are a lot of e-mails sent šŸ˜•
Does anyone have the same problem? Or should I open a GTAC case?!
This is the NetSight Error Log during the Upgrade:
2016-08-23 22:49:39,509 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [3 updateDeviceStatus - Error sending device change messages] details:
com.enterasys.netsight.api.lockmgr.NSLockException: Could not acquire lock.
at com.enterasys.netsight.api.lockmgr.NSLock.acquire(NSLock.java:166)
at com.enterasys.netsight.server.ServerContext.acquireDeviceTreeWriteLock(ServerContext.java:750)
at com.enterasys.netsight.server.device.DeviceServiceImpl.updateObjectsInternal(DeviceServiceImpl.java:346)
at com.enterasys.netsight.server.device.DeviceServiceImpl.updateDeviceStatus(DeviceServiceImpl.java:318)
at com.extreme.common.poller.PollerUtils.updateDeviceStatus(PollerUtils.java:216)
at com.extreme.common.poller.SnmpStatusPollerTask.complete(SnmpStatusPollerTask.java:194)
at com.extreme.common.network.task.Task.complete(Task.java:553)
at com.extreme.common.network.request.RequestSnmp.processRequest(RequestSnmp.java:110)
at com.extreme.common.snmp.SnmpEngine$SnmpWrapper.doComplete(SnmpEngine.java:272)
at com.extreme.common.snmp.SnmpEngine$SnmpWrapper.access$300(SnmpEngine.java:156)
at com.extreme.common.snmp.SnmpEngine$SnmpWrapper$1.run(SnmpEngine.java:195)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2016-08-23 22:49:40,119 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [2 updateDeviceStatus - Error sending device change messages] Message:Could not acquire lock. Cause:null
Called from:
Line:194 com.extreme.common.poller.SnmpStatusPollerTask method:complete
Line:553 com.extreme.common.network.task.Task method:complete
Line:110 com.extreme.common.network.request.RequestSnmp method:processRequest
Line:272 com.extreme.common.snmp.SnmpEngine$SnmpWrapper method:doComplete
Line:156 com.extreme.common.snmp.SnmpEngine$SnmpWrapper method:access$300
Line:195 com.extreme.common.snmp.SnmpEngine$SnmpWrapper$1 method:run
2016-08-23 22:49:40,119 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [3 updateDeviceStatus - Error sending device change messages] Message:Could not acquire lock. Cause:null
Called from:
Called from:
Called from:
2016-08-23 22:49:39,820 ERROR [org.jboss.mq.server.JMSDestinationManager] The connection to client ID:98 failed.
2016-08-23 22:49:39,509 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [5 updateDeviceStatus - Error sending device change messages] details:
2016-08-23 22:49:39,509 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [2 updateDeviceStatus - Error sending device change messages] details:
2016-08-23 22:49:39,509 ERROR [com.extreme.common.poller.PollerUtils] processThrowable [4 updateDeviceStatus - Error sending device change messages] details:
Thanks in advance!
Cheers,
Martin
8 REPLIES 8
MartinS1
The 1st backup takes about 3 minutes (~125MB), the 2nd takes about 51 minutes (~17GB)
02f1f21190cc4509a45cb8248c278b9d_RackMultipart20160830-28472-vtvith-DB_Backup_2016-08-30_Console-events_-_Copy_inline.png
Just before the finish of the second backup, there is a massive utilization of the disks.
This seems to be the problem which was not there before the update.
I'm going to open a GTAC-case šŸ˜•
regards,
Martin
Frank_Thomas
How big are your Database backups also how long do they take to complete? The completion time should be in console event logs.
I'm going to check tomorrow, as it's the system of a customer I don't have access to it every day ļ˜‰
Jeremy_Gibbs
Contributor
I am no expert, but it sounds like your server might be running out of resources... Do you monitor the CPU / disk utilization at all?
