The configuration template does not work by using restore configuration.
Yuki_Nakamura
New Contributor II
Hi
I am thinking that create a configuration template and mass produce devices with the same settings.
Even if I use the configuration template from the restore configuration, but the configuration is not reflected in the switch(VOSS) configuration.
Please tell me how to use the setting template.
Best Regards,
Yuki Nakamura
0 REPLIES 0
