There is no switch discovery in ZTP.
Vicent3
Hello,
I am configuring ZTP but the switch is not discovered, I have the following configuration.
The switch is a X440G2-12p-10G4 model, with a version 30.5.1.15.
Netsight version is  8.4.3.24.
The Switch takes IP by DHCP, I contact it by ICMP and I can telnet to it but in EMC it is not discovered.
Additionally, I already validated that you are resolving extremenetwork with the Netsight IP address but I still don't see anything in the discovered tab.
How can I resolve this situation?
1 ACCEPTED SOLUTION
Rodney_Lacroix
Does your Operations panel say that the devices are being discovered? If so, then check your Actions tab and make sure the “Automatically Add” option is enabled.
5 REPLIES 5
TylerMarcotte
Hi @Vicent3 - I believe the A record you need in DNS is extremecontrol.domainname vs. extremenetwork.
If you haven’t reviewed it yet, there is a great GTAC Knowledge article availalbe here as well: https://gtacknowledge.extremenetworks.com/articles/How_To/What-configuration-is-needed-for-ZTP-Zero-...
