‎07-05-2017 02:38 PM
A feature that we used quite a bit in NetSight was Capacity Planning which could be found on the Tools menu in Inventory Manager. With the deprecation of the Inventory Manager java app, have we lost this functionality?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎07-25-2019 01:48 AM
Hi All,
Capacity Planning can be found on the Network Tab under Dashboard>Inventory>"Capacity Planning"
Full instructions here:
https://emc.extremenetworks.com/content/oneview/docs/network/docs/l_ov_network.html#dashboard
9 REPLIES 9
‎07-25-2019 12:11 AM
I'm running Extreme Management Center 8.2.5.50, upgraded from netsight a few months ago.... After a lightning strike and multiple dead switches, I desperately need to run the unused port query. I just discovered, its basically non-existent in Management center. Has this been resolved recently?
‎10-30-2018 07:38 PM
I have the same question as well, the command line is great but only if you clear counters and take a look later on, it seems like there is some functionality setup to be similar to the old Capacity Planning in some way?
‎06-07-2018 12:56 PM
I have this same question - and it doesn't appear that this was answered properly.
Does anyone know where the "Capacity Planning" went when it was carried over to XMC OneView?
*EDIT* - I found that running this from the CLI on the switch it pretty helpful ...
show port info detail | inc Port:|Link\sState:|Link\sUps:|Link\sDowns:That came from Brandon Clay on this thread.
‎08-18-2017 10:38 PM
Hi ,thanks but doesnt actually explain to generate the reports. Just tells you how to archive the capacity planning data itself
