‎05-22-2026 08:37 AM
Good Evening,
I have an Extreme 4220 VOSS switch with all ports configured in Auto-Sense mode, and I would like to connect an XOS switch using Fabric Attach.
The management VLAN on the VOSS switch is VLAN 199, and I would like the XOS switch to be configured automatically on the same VLAN as well.
I was thinking about using ZTP+ for this purpose. Is it possible?
Thanks in advance
Giuseppe
3 weeks ago
Hello,
This is not what you asked for but, link below shows you the manual configuration.
"https://extreme-networks.my.site.com/ExtrArticleDetail?an=000077283&q=how%20to%20configure%20fabric%...
You can also try searching the EXTREME Support Portal.
a month ago
I think it could be posable. Look through the Site Engine documentation to find out the way to implement it for you.
