Hello, everybody!
I have a network full of CISCOs and Netsight 6.3. I've discovered all the CISCOs using Netsight console and then added them on the topology map in OneView.
The problem is not only absence of the links (it's because of LLDP is turned off), but I haven't Links and VLAN menu option in Network detail pane on the right. I've saved the map but no results.
Could you please explain me - may I have a topology map with links for networks where are no any extreme or enterasys switches?
Many thanks in advance,
Ilya
