Wireless Manager v5.5
Jamie_Archer_Ja
Applying a WLAN to WAPs, I have set up a new SIDD and want to assign it to several WAP how do i do this ?
2 REPLIES 2
Jamie_Archer_Ja
Thank you that's done the trick
lhuso
New Contributor II
When you have created the Wireless service you must go into Configuration/Profiles and interfaces/Radios. Select a radio and choose Wlan Mapping. On the right side, under Wlans, you should se your SSID. Move it with the arrows to the left side and click OK. Then save and commit.
