Xiq-se and switches Alcatel
Giuseppe_Montan
Contributor
Good Morning,
Customer with 5 sites and 40 switches Alcatel and 20 Extremenetworks 4220.
On site where there are not Extreme switches I have a map but I do not have a link between switches.
Do you have experience with these switches ? are there compatibile with Xiq-SE ?
Thanks in advance
Giuseppe
4 REPLIES 4
Robert_Zdzieblo
Contributor II
Hi Giuseppe,
Please be sure, if you have LLDP enabled on uplink ports between switches.
REGARDS, Robert
Thanks, I hace checked and lldp is active on uplink.
I can create manually but after some time ( minutes ) the link disappear from webpage 😞
Giuseppe
Can you see LLDP neighbors on other side of the links?
Yes, If I connect direactly to the Alcatel switches I am able to see LLDP information, Only Xiq-SE MAP does not see LLDP neighboor. 😞
