‎05-20-2023 05:06 AM
Hello, is it possible to create a service ( policy )
that simultaneously blocks access to an ip on a specific port
while allowing access to the same ip on other ports?
For example, can I create a service to my server 192.168.0.1:3389 and permit access to 192.168.0.1:443
Thanks
Giuseppe
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎05-20-2023 05:26 AM
2 REPLIES 2
‎05-22-2023 05:52 AM
Thanks.
Giuseppe
Sure you can.
Regards
Zdeněk Pala
