10-07-2026 04:38 AM
Im curious how others are using the UserData fields in XIQ-SE? I have several python scripts that populate 'InService' dates; Powersupply wattage; local accounts; and auth type (local,radius,tacacs)
What are some other good ideas you have come up with?
a month ago
Once these fields are populated via your Python scripts, remember to leverage Dynamic Device Groups and Custom Reports inside XIQ-SE. You can create saved views that group devices by custom parameters—such as displaying all switches running an outdated golden image or filtering devices by a specific cost center.
10-07-2026 05:30 AM
Hi.
I have seen notes like "this device is installed under the table" and "let the person in the room XXX know if you enter the closet"...
