09-22-2020 02:05 PM
We installed a new xmc server from scratch. Now after re-creating Sites/devices/profiles/users/scripts …
We would like to associate profiles to device like on the old server without creating it by hand.
Is it possible to retrieve from our old server, the “Administration → Profiles → Device Mapping” spreadsheet via an API script ?
Or is there an entry corresponding to this table into the NBI or else where (sql database) ?
If anybody can help.
Regards
Rija
Solved! Go to Solution.
09-22-2020 02:09 PM
following NBI can give you the mapping for XMC. I am not aware of group to profile mapping.
network {
devices {
ip
deviceData {
profileName
09-23-2020 07:36 AM
This is exactly what i need.
Thank you so much !!!
09-22-2020 02:59 PM
here is the command you can use to get the data through the XMC shell:
cd /usr/local/Extreme_Networks/NetSight/scripts/
./mysql.sh
use netsight
select nsdevices.ip, nsusergroups.groupname,nsprofiles.profilename from nsgrouptoprofile inner join nsusergroups on nsgrouptoprofile.GROUPID = nsusergroups.GROUPID INNER JOIN nsdevices on nsdevices.DeviceID = nsgrouptoprofile.DeviceID inner join nsprofiles on nsgrouptoprofile.profileid = nsprofiles.profileid;
I know it is not API call, but may help you...
12-09-2024 05:20 PM
Thanks for this query! When we add a new device to XIQ-SE, I would like it to automatically get a "device mapping" of what operators can see it etc. according to its site. I am not familiar with writing sql but could we modify the above query to insert a new entries for a new IP with all the operators getting this or that profile?
I am asking because it does not seem that "Device mapping" matrix values are available in the NBI to manipulate with a workflow.
With the above ask to insert in the sql database I think I could get python to do that in a workflow. I just don't know sql at all. Thanks
09-22-2020 02:28 PM
Thank you fr the information.
I’ll ask the GTAC to know if its possible
Regards
Rija
