XMC - Discover Devices Using ICMP / PING ONLY
‎10-15-2021 09:52 AM
We would like to discover devices with ping only.
We have follow this KB to use legacy console
https://extremeportal.force.com/ExtrArticleDetail?an=000058862
But when we use "Discover Networks" it find no devices!!
No problem if we add devices one by one with "Add device"
XMC version 8.5.6
Regards
XMC version 8.5.6
Regards
6 REPLIES 6
‎10-16-2021 06:15 AM
this feature is on the roadmap for ExtremeCloud IQ - Site Engine.
Stay tuned!
Z.
Stay tuned!
Z.
Regards
Zdeněk Pala
‎10-18-2021 03:40 AM
Ok for the roadmap in XIS- SE.
But it should working in legacy console .... as in KB
Regards
Regards
‎10-18-2021 08:38 AM
The PING ONLY discovering function, per the GTAC KB, only works in the legacy console and only works if the 32-bit version of Java Runtime Engine (JRE) is installed on the client system. If only the 64-bit version of JRE is installed, the legacy console ICMP/PING ONLY discovery function does not work.
As Zdenek stated, this feature will become available in a future release of ExtremeCloud IQ - Site Engine. It is not destined for XMC.
‎10-18-2021 09:11 AM
Yes, it's working with java 32 bits
Thx
Thx
