XMC - Discover Devices Using ICMP / PING ONLY
Jchasles
We would like to discover devices with ping only.
We have follow this KB to use legacy console
https://extremeportal.force.com/ExtrArticleDetail?an=000058862
But when we use "Discover Networks" it find no devices!!
No problem if we add devices one by one with "Add device"
XMC version 8.5.6
Regards
6 REPLIES 6
Zdeněk_Pala
this feature is on the roadmap for ExtremeCloud IQ - Site Engine.
Stay tuned!
Z.
Regards Zdeněk Pala
Ok for the roadmap in XIS- SE.
But it should working in legacy console .... as in KB
Regards
The PING ONLY discovering function, per the GTAC KB, only works in the legacy console and only works if the 32-bit version of Java Runtime Engine (JRE) is installed on the client system. If only the 64-bit version of JRE is installed, the legacy console ICMP/PING ONLY discovery function does not work.
As Zdenek stated, this feature will become available in a future release of ExtremeCloud IQ - Site Engine. It is not destined for XMC.
Yes, it's working with java 32 bits
Thx
