XMC floorplan image quality
‎11-06-2018 07:37 AM
Hi all, I have uploaded a.jpg picture for my floorplan. This is a big building. So the original.jpg is like 7 MB and we can zoom in so we can see each room. Now, after uploading it to XMC, i am unable to get the same quality. When zooming in, we are unable to read the room numbers. Is there a way that XMC can use the same image quality as the original one?
6 REPLIES 6
‎11-07-2018 12:26 AM
Hi, We tested it and it worked! for other people that want to adjust it, The file is in this folder:
./usr/local/Extreme_Networks/NetSight/appdata/NSJBoss.properties
Hi Karthik, Thank you for the response. So the version we using is 8.1.4.40. Im going to test the solution and let you know if it worked.
