10-06-2020 04:49 PM
I’ve noticed that ECIQ is now applying this FW version as latest version, but I could not find the release notes.
Solved! Go to Solution.
10-06-2020 05:06 PM
Hi John! Here are the release notes for 10.0r9b:
http://docs.aerohive.com/330000/docs/help/english/documentation/10.0r9b_IQEngine_ReleaseNotes.pdf
10-07-2020 01:51 PM
Unless the issue was still present after the 10.0r8a release, the fix won’t be listed in later release notes. The release notes will only mention issues that specific version is meant to fix. All fixes that were present in 10.or8a will be present in all later firmware versions as we build on the old software instead of starting from scratch.
10-07-2020 01:47 PM
Hi Sam,
since 10.0r9b is the latest supported release for AP650 according to http://docs.aerohive.com/330000/docs/help/english/ng/Content/learning-whats-new.htm, where are all the fixes from 10.0r8a?
They are nowhere mentioned in releases 10.0r9 / 9a / 9b ?!
10-06-2020 05:06 PM
