ā03-06-2021 09:54 AM
Hi guys,
I get customer feedback that if i migrate AP130 access point from classic to the ExtremeCloud IQ that the LED is permanently on compared to before were it was in LED saving mode which would just let the LED light up every 3-5 minutes. I find in the management options a note that only a few APs support dim or light LED mode but it doesnt make sense because in Classic the same AP supported the power saving mode. Is there a CLI command to but the AP back in to LED mode were it lights only up everyonce in awhile? If I use the topology view and set the AP to blinking it will blink fast, not what i am after : )
Best,
Andi
Solved! Go to Solution.
ā03-10-2021 03:04 PM
Sorry about that, looks like the command has changed a bit. You need to add in how many seconds you want the LED to be on, and how many seconds you want it be off. To get back to the original behavior of having the LED on for 4 seconds, then off for 56 seconds, try this command:
#system LED power-saving-mode on 4 off 56
Iāll flag that guide to get it updated, my apologies for the confusion.
ā03-10-2021 12:15 PM
system led brightness off
This would kill the led completely..
ā03-10-2021 09:54 AM
Dear Sam,
somehow I get an error using the CLI command:
System LED power-saving-mode on
This should work with Cloud CLI-command as well shouldnāt it? Have you got a chance to test it
on a AP? I tried on two different ones but the command didnt work. What am I doing wrong š ?
Cheers
Andi
ā03-08-2021 04:08 PM
Hi Andi, this guide reviews the CLI commands to enable the LED saving mode, are these what you were looking for? https://extremeportal.force.com/ExtrArticleDetail?an=000056739&q=LED%20saving%20mode
You could create a supplemental CLI object to keep these commands active even after a reboot of the device(s).
