07-23-2026 03:58 AM
Hello team,
we have connection between Border leaf and spine switch, instead of one /31 ip it has multiple /31 ip address which is not known. Please help to get them deleted and what would be impact while deleting is as site is live .
interface Ethernet 0/4
description Link to 192.168.246.31 Spine
ip address 10.10.10.71/31
ip address 10.10.10.80/31
ip address 10.10.10.82/31
ip address 10.10.10.84/31
ip address 10.10.10.86/31
ip address 10.10.10.88/31
ip address 10.10.10.90/31
ip address 10.10.10.92/31
ip address 10.10.10.95/31
ip address 10.10.10.97/31
ip address 10.10.10.98/31
ip address 10.10.10.100/31
ip address 10.10.10.102/31
ip address 10.10.10.104/31
ip address 10.10.10.106/31
ip address 10.10.10.108/31
ip address 10.10.10.110/31
ip address 10.10.10.112/31
ip address 10.10.10.115/31
ip address 10.10.10.116/31
bfd interval 200 min-rx 200 multiplier 3
no shutdown
Solved! Go to Solution.
07-23-2026 06:19 AM
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000117681
07-28-2026 06:06 AM
"efa inventory device update" does not push any configuration, it simply updates XCO with the current status of the Fabric device
The only time configuration is pushed is with a DRC or fabric configure.
DRC:
"efa inventory drift-reconcile execute --ip [IP_ADDRESS] --reconcile"
- If the --reconcile flag is not used, no config is changed, XCO simply prepares a list of drifted config you can view in "efa inventory drift-reconcile detail --uuid"
Fabric Configure:
"efa fabric configure --name [FABRIC_NAME]"
I would run a DRC.
07-28-2026 12:54 AM
Thanks Michael, i have applied the WA but i have seen one strange thing that BFD and description of the fabric interface is not pushed by EFA while doing device update
it has only ip address and both the side and underlay bgp is up but no bfd , like other fabric interfaces . any reason ?
07-28-2026 06:06 AM
DRC:
Fabric Configure:
I would run a DRC.
07-29-2026 07:34 AM
thank you so much Michael
07-23-2026 06:19 AM
