NAC with 802.1x authentication problem
truefast
Hello everyone,
i've a strange problem on a customer's NAC that we recently configured, with a pc test which has only few GPO policy i can authenticate, it correctly goes online, search the web, and most important i can reach the siteengine page (the certificate fails tho) and sucesfully make the login.
With another pc (more than one) i can do all the above but when i try to reach the site engine webpage it says the usual phrase that the page is unsecure and if i want to continue (like the above example) but then it goes in timeout.
Now i've check everything, it authenticate on the correct role, gets the ip address, i can see it has no errors on the site engine but i cant reach this resource, i think is a GPO in which these machines are into (i've no access to their AD), but could it be some misconfiguration on the nac engine?
Thanks
0 REPLIES 0
