08H20G4-48P problems after power outage.
Rahman_Duran1
New Contributor III
I am having issue with 08H20G4-48P lately. After a few power outages the switch does not forward any traffic. I can access it remotely via Web GUI and via ssh without any problem. But I can't access any other devices that are connected to it. Also the connected devices can't access beyond it. Rebooting it via cli or powering off/on it solves the problem.
What should be the problem? It has latest available firmware installed.
Thanks,
Rahman
7 REPLIES 7
Karthik_Mohando
Hi Rahman, Stephen is referring to the issue which is documented in this link https://gtacknowledge.extremenetworks.com/articles/Solution/Traffic-is-filtered-by-the-switch-with-default-configuration if you still could not execute the command can you post the "show switch" and the output what you get during the command execution.
Stephen_Elliot1
Contributor
perhaps you've hit that weird forwarding 'feature' which disables flooding.
check your config, does it have any 'disable flooding' commands?
try " enable flooding all_cast ports all"
Well, it does not accept any commands like "enable flooding".
