We are looking at using the 40Gbe fanout cable with s series 40Gbe blade.
The Datasheet for the 40Gbe fanout cable only lists summit switches.
Will this cable work with the 40Gbe S series blade?
What is the part number of the cable assembly you are looking to use?
The ones that I am aware that are tested on the S series are:
10GB-4-C03-QSFP
10GB-4-F10-QSFP
10GB-4-F20-QSFP
