DB9 Console cables for C5 and B5 switches
Phillip_Hood
I am looking for information for an adapter to use with our C5G and B5 switches for the console port. We have a couple of aging laptops let with Windows Vista that have a serial port on them and I want to get away from those laptops and use what we currently have. Is there a USB to DB9 or RJ45 to DB9 that can be used for these with a Windows 7\10 laptop? Does the switches support this?
Thanks in advance.
6 REPLIES 6
Thanks a bunch. Will look into getting a couple of these.
I believe those only work the other way. The RJ45 would connect to the switch.
Those RJ45 to DB9 are for RJ45-made console ports on old cisco's
