Where to download legacy firmware (EOS)?
aloeffle
Contributor
Dear all.
On and off I need specific legacy firmware versions for Enterasys devices running EOS. C-Series, B-Series, etc.
Since we have a new portal, I do not find all the old versions for all legacy EOS products.
Some are there, but not all.
d2e68f5a85a8466a99c286f46851c0bb_RackMultipart20170829-85575-go703z-extremednld_inline.jpg
For example C2/3 and B2/3 are missing.
Where to download firmware for these models?
thanks and best regards
Alexander
45 REPLIES 45
dantecl
+1 on Enterasys C3 firmwares. I have 2 C3 switches, one on 06.03 and the other on 06.61 and I can't stack them because of this. Would love to upgrade the older one to 06.61 but I can't extract the firmware from the newer switch. Can't open a support case either, gives me some weird error. Help?
Matt26
New Contributor II
Hi Drew, Any progress on the old firmware portal? I would love to upgrade my C2G124-24.
Cheers,
Matt.
Matt26
New Contributor II
Thanks Drew. My current FW on the switch is:
C2G124(su)->show ver
Model Serial # Versions
C2G124-24 04440141900N Hw:BCM5695 REV 17
Bp:01.00.46
Fw:05.02.01.0006
BuFw:04.00.31
Drew_C
Valued Contributor III
Matt, I don't see any of the C2 or C3 software on the portal... at least not by searching based on filename prefixes.
I'll need to find out what I'm able to do here since I found some of the software internally.
Rich_Pacheco
New Contributor III
Same here. Where can I download the C3 firmware?
-Rich P.
