MHSA/MHMA automation
Fijs
New Contributor III
We're deploying NAC in an existing network of mainly ERS49XX and ERS48XX switches.
On these ERS switches, one needs to specify if a port needs to be in MHSA or MHMA mode.
For example:
  • our access points need MHSA (AP authenticates, connected clients do not since they're authenticated elsewhere)
  • IP phones need MHMA: both the phone and the connected PC need to authenticate
Is there a way to configure MHSA/MHMA dynamically, so can configure all access ports exactly the same, and we don't have to care where to connect AP's or phones?
Thanks!
1 ACCEPTED SOLUTION
Miguel-Angel_RO
Valued Contributor II
Fijs,
On ERS 4900 as from 7.9.1:
317a318d949e4da48719d96453fbb4e1.pngHere for the ZTC for ERS:
5a8eab328e4547a88eabc2e6aae0aecc.pngI suggest you to read the doc ConfigFabConERS49005900_7.8.1_CG.pdf
Mig
6 REPLIES 6
Fijs
New Contributor III
Thanks Mig! I'll give it a try.
Miguel-Angel_RO
Fijs,
Mig
