Cant SSH2 to Extreme switches via Ubuntu
Marvell_Kay
New Contributor II
We recently enable SSH2 in our environment. I am able to SSH to Cisco switches without any issue but can not to any Extreme switch. I can login to them fine via teraterm/secureCRT but not via Ubuntu.
I have a Ubuntu 14.04 machine. Here is what I am getting:
ssh admin@extreme_switch.com
ssh_exchange_identification: read: Connection reset by peer
With -v for more info:
ssh -v admin@extreme_switch.com
OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to extreme_switch.com [10.10.0.99] port 22.
debug1: Connection established.
debug1: identity file /home/admin1/.ssh/id_rsa type -1
debug1: identity file /home/admin1/.ssh/id_rsa-cert type -1
debug1: identity file /home/admin1/.ssh/id_dsa type -1
debug1: identity file /home/admin1/.ssh/id_dsa-cert type -1
debug1: identity file /home/admin1/.ssh/id_ecdsa type -1
debug1: identity file /home/admin1/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/admin1/.ssh/id_ed25519 type -1
debug1: identity file /home/admin1/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.8
Any idea why I can not login to Extremes?
Thanks
Zohaib
18 REPLIES 18
Marvell_Kay
New Contributor II
We have different versions depending on model. Here are some and none are working:
8810/x8 - bd8800-15.7.2.9-ssh.xmod v1572b9
x770 - summitX-15.7.2.9-ssh.xmod v1572b9
x870 - onie-22.2.1.5-patch1-4-debug.xmod 22.2.1.5-patch1-4
Here is a snippet of "sh man":
SSH access : Enabled (Key valid, tcp port 22 vr VR-Mgmt)
: Secure-Mode : Off
: Access Profile : 25 Dynamic rules configured
SSH2 idle time : 60 minutes
SSH is enabled as I can SSH to all devices via SecureCRT
If you run {show man} is ssh enabled?
If not you can
{enable ssh2}
davidj_cogliane
Contributor
What version of code are you running?
Is the ssh xmod installed if you are running 15.x or lower?
