EXOS how to reset a port to factory default
bw447
New Contributor III
Is there a way to reset a port back to factory default. For instance if I have a port with 7 vlans tagged and 1 untagged with elrp on the port, how can I get the port back to just vlan default untagged without having to delete each vlan manually and disabling elrp manually. Thanks in advance!
1 ACCEPTED SOLUTION
# configure ports X auto on
It's enough
17 REPLIES 17
Jhonn_Bejar
as I could not think, thanks Andrea. Excellent. I was looking for this.
andreas1
New Contributor II
Yes that is correct it removes stp etc and such from the port not sure about ethtype etc but it removes all the vlan information at least.
bw447
New Contributor III
@Andrea, thanks for the idea. When you turn on mirroring it removes all settings, is that correct? I quick command to clear everything. Again, I like the idea.
andreas1
New Contributor II
You can remove all the vlans from a port easily.
enable mirroring to port X
then
disable mirroring
This command I have to run quite frequently since it is a hassle to remove over 100 vlans from one port.
I wish there was a enable port default-settings port X
then with a question to confirm this.
ZakaMede1
This Forum is probably the best forum that i have ever used and i would just like to say how proud i am to be a member of this forum
