extreme switch connected to cisco switch and losing packet
Siva2
Hi All
Can someone help me, I have 2 ExtremeXOS 440 switches version 21.1.1.4 connected to cisco switch 6500.
Problem : when I’ doing continues ping I’m getting packet loss and when one switch responding to my pings another will not respond vice vasa .
This is my configuration on extreme switches
create vlan "internal-man-105"
configure vlan internal-man-105 tag 105
configure vlan internal-man-105 add ports 2:24 tagged
configure vlan internal-man-105 ipaddress 1.1.1.1 255.255.255.248
enable ipforwarding vlan internal-man-105
configure ports 2:24 auto on speed 1000 duplex full
this is my configuration on cisco switch
interface GigabitEthernet3
description Extreme-switch Uplink
switchport
switchport mode trunk
logging event link-status
logging event trunk-status
logging event bundle-status
logging event spanning-tree status
logging event subif-link-status
load-interval 30
keepalive 30
speed 1000
duplex full
udld port aggressive
mls qos trust cos
flowcontrol receive on
flowcontrol send on
spanning-tree portfast edge trunk
spanning-tree bpduguard enable
end
21 REPLIES 21
any speed command on cisco disables auto-negotiation
to re-enable auto-negotiation you should issue
no speed
under selected interface
speed 1000 on Cisco IOS uses auto-negotiation, speed 100 disables it
I hope not. Gigabit should always use auto negotiation. Try speed auto on Cisco.
An please check the error counters. Without a picture of you network and a detailed
error description it's just fishing in the dark.
Hi Patrick
I have check Spanningtree on cisco log i dont see and any errors so i believe Spanningtree is not an issue problem .
* Slot-2 Stack.1 # configure ports 2:24 auto off speed 1000 duplex full Error: Auto negotiation off is not supported on copper medium of combo port 2:24 at 1G or 10G speed.
when I try to make it off i'm getting above error
How to configure speed on EXOS not to be auto ?
Patrick_Voss
Hello Siva,
What switch are you pinging and where are you pinging from? What are the IP addresses of each switch?
