extreme switch connected to cisco switch and losing packet
Siva2
Hi All
Can someone help me, I have 2 ExtremeXOS 440 switches version 21.1.1.4 connected to cisco switch 6500.
Problem : when I’ doing continues ping I’m getting packet loss and when one switch responding to my pings another will not respond vice vasa .
This is my configuration on extreme switches
create vlan "internal-man-105"
configure vlan internal-man-105 tag 105
configure vlan internal-man-105 add ports 2:24 tagged
configure vlan internal-man-105 ipaddress 1.1.1.1 255.255.255.248
enable ipforwarding vlan internal-man-105
configure ports 2:24 auto on speed 1000 duplex full
this is my configuration on cisco switch
interface GigabitEthernet3
description Extreme-switch Uplink
switchport
switchport mode trunk
logging event link-status
logging event trunk-status
logging event bundle-status
logging event spanning-tree status
logging event subif-link-status
load-interval 30
keepalive 30
speed 1000
duplex full
udld port aggressive
mls qos trust cos
flowcontrol receive on
flowcontrol send on
spanning-tree portfast edge trunk
spanning-tree bpduguard enable
end
21 REPLIES 21
Karthik_Mohando
configure ports 2:24 auto on speed 1000 duplex full as per the port number 2:24 it looks like a stacking switch to me but anyways can you share the "show switch" output from both the switches ?
Patrick_Koppen
Contributor
Hi Siva,
error counters look normal (pause is strange...). Could you tell us a little more about you problem?
  • What is the IP of your laptop?
  • Which port is you laptop connected to?
  • What are the exact timings of the packet losses (e.g. loss after every 30 seconds, or work for 10 seconds, stopps for 60 seconds....)?
But still... it could be anything...
Regards
Patrick
Karthik_Mohando
Siva, Are the two switches(10.1.1.2,10.1.1.3) are in stacking? If so can you post the "show switch" output from both the switches?
Patrick_Koppen
Contributor
Hi Siva,
on EXOS you turned auto-negotiation on and advertise only 1000/full.
Are you sure duplex full and speed 1000 does not turn auto-negotiation off on cisco?
Spanningtree or udld could be a problem. You should look at the error counters, fdb,
spanningtree, link state, ..... Turn on logging on IOS and EXOS. Does any happen?
Link los, errors disable, duplicate ip, arp change, TCN, ...?
show ip int brief
show interface
show controllers GigabitEthernet3
Regards
Patrick
Hi Nick,
"speed 1000" on Cisco IOS does not disable auto-negotiation, it just restricts the advertised speeds to gigabit only. This is a trap I have seen many people fall into when trying to interconnect non-Cisco and Cisco switches with a "fixed" speed of 1000.
Thanks,
Erik
