07-30-2020 05:22 PM
Hi Tech people
i have 3 X460-G2-10G Extreme Switches in a ring topology. i am using Extreme 10G ShortRange SFP(850nm) module for interconnections between rings on front panel Port 51,52. The problem is that, the Ports are Stuck in Ready State. Physical link is not showing any connectivity.
Firmware between switches are,
Swithc 1 Image : ExtremeXOS version 22.6.1.4 by release-manager
Switch 2 Image : ExtremeXOS version 30.2.1.8 by release-manager
Switch 3 Image : ExtremeXOS version 30.2.1.8 by release-manager
Thanks for Support.
07-31-2020 12:34 PM
Is the receive level -40 at both ends or just one end. If your not getting light it has to be a fiber issue or an optic that is not transmitting.
If you see light but don’t get a link we can talk about port configs, but you need the light...
07-30-2020 06:18 PM
Hi David Thanks for your reply,
I suppse the ports already enable and showing Ready Status. i already configure the following command and test the port
configure port 51 auto off speed 10000 duplex full
in actuall the two swithces in a same cabinet 1 are connected via 10G SFP DAC Cable and no issue in connectivity. One switch is in cabinet 2 (10 meter away) is connected to the two switches in cabinet 1 via 10G SFP Module. The problem is in this connections. (connection diagram attached)
07-30-2020 05:55 PM
So you are not seeing any light from the other end.
I would start by flipping the fiber at one end and see what happens / rerun the command.
run the same command after each step, receive levels should be between -5 and -10.
SR optics should transmit red light which is visible if you look at the optic or end of the patch cable. Looking at lasers may be bad for you and I am not making any recommendations to stare into a laser.
07-30-2020 05:44 PM
Hi david Thanks for your reply
i issue following command
show port 51 transceiver info
i notice that the Rx Power is -40.00* which showes that the Power related paremeter are not normal. we performed the basic troubleshooting related to fiber. we used Fiber Attenuator to test but Same error.
