Extreme x620-16t Inventory manager archive error "Connection Refused" CLI access is not enabled
Phillip_Hood
I have 2 x620-16t switches that my coworker has setup. The 2nd switch was setup using the config from the first one and had the IP changed so the config should be the same. However, I am not able to get the archive working in EMC/Inventory Mgr. It gives the error "Connection refused, CLI access is not enabled for this device". I got the first one working but this one will not. How to I enable this when all settings that I know of are or should be the same as the first switch?
17 REPLIES 17
They are the same.
Patrick_Voss
Hello Phillip,
Do you have any configuration on either switch in relation to an access profile or any type of security configuration?
Are you talking about the SNMP profile? They are both set to the same as all other switches.
