How to configure VPLS L2VPN Pseudo Wire with MPLS
Matt_Tinonga
New Contributor II
Hello, I'm needing some help setting up a layer 2 vpn between two X460-24t across a wan. I have all the necessary licensing and feature packs installed. The wan used static routing and is 3 hops away, also the routers in between do not participate in the MPLS. I've started setting up the MPLS and VPLS here's where I'm at...What am I doing wrong?
Switch #1 name ldc-xm0-nsw012
ldc-xm0-nsw012.19 # sh vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 ------------------------------------------------- ANY 0 /0 VR-Default
ent_sp0-int001 3151 209.249.151.250/24 ---------------------V------- ANY 1 /2 VR-Default
lpbk 4094 192.168.0.1 /32 -fL------------------l------- ANY 0 /0 VR-Default
Mgmt 4095 10.55.211.20 /24 ----------------------------- ANY 1 /1 VR-Mgmt
snj_si0-bkd022 3155 172.31.55.2 /24 -f-------------------l------- ANY 2 /2 VR-Default
ldc-xm0-nsw012.19 # sh ipr
Ori Destination Gateway Mtr Flags VLAN Duration
#s 172.31.22.0/24 172.31.55.251 1 UG---S-um--f- snj_si0-bkd022 4d:21h:25m:29s
#d 172.31.55.0/24 172.31.55.2 1 U------um--f- snj_si0-bkd022 4d:21h:26m:52s
#d 192.168.0.1/32 192.168.0.1 1 U------um--f- lpbk 4d:20h:11m:46s
#d 209.249.151.0/24 209.249.151.250 1 U------um--f- ent_sp0-int001 4d:21h:48m:51s
ldc-xm0-nsw012.20 # sh conf mpls
# Module mpls configuration.
configure mpls add vlan "lpbk"
enable mpls vlan "lpbk"
enable mpls ldp vlan "lpbk"
configure mpls add vlan "snj_si0-bkd022"
enable mpls vlan "snj_si0-bkd022"
enable mpls ldp vlan "snj_si0-bkd022"
configure mpls lsr-id 172.31.55.2
enable mpls protocol ldp
enable mpls
create l2vpn vpls ldc-snj-vpn fec-id-type pseudo-wire 25
configure l2vpn vpls ldc-snj-vpn add service vlan ent_sp0-int001
configure l2vpn vpls ldc-snj-vpn add peer 172.31.22.2 core full-mesh
ldc-xm0-nsw012.21 # sh vpls detail
L2VPN Name: ldc-snj-vpn
VPN ID : 25 Admin State : Enabled
Source Address : 172.31.55.2 Oper State : Enabled
VCCV Status : Disabled MTU : 1500
VCCV Interval Time : 5 sec. Ethertype : 0x8100
VCCV Fault Multiplier : 4 .1q tag : exclude
L2VPN Type : VPLS Redundancy : None
Service Interface : ent_sp0-int001
Created By : CLI
Peer IP: 172.31.22.2
PW State : Signaling (No transport LSP)
PW Index : 10002
PW Signaling : LDP
PW Uptime : 0d:0h:0m:0s
PW Installed : False
Local PW Status : Not Signaled
Remote PW Status : Not Signaled
Remote I/F MTU : 1500
PW Mode : Core-to-Core
PW Rx Label : 0x00434 PW Tx Label : 0x00434
PW Rx Pkts : -- PW Tx Pkts : 0
PW Rx Bytes : -- PW Tx Bytes : 0
MAC Limit : No Limit
VCCV HC Status : Not Sending (VCCV Not Enabled For This L2VPN)
CC Type : Rtr Alert Total Pkts Sent : 0
CV Type : LSP Ping Total Pkts Rcvd : 0
Send Next Pkt : --
Total Failures : 0 Pkts During Last Failure : 0
Last Failure Tm : --
Total number of configured L2VPNs: 1
Total number of active L2VPNs: 0
Total number of configured PWs: 1
Total number of active PWs: 0
Total number of ready PWs: 0
PWs auto-selecting transport LSP: 0
PWs configured with a transport LSP: 0
PWs using LDP for transport: 0
PWs using RSVP for transport: 0
PWs using static for transport: 0
ldc-xm0-nsw012.22 # traceroute 172.31.22.2
traceroute to 172.31.22.2, 30 hops max
1 172.31.55.251 2 ms 1 ms 1 ms
2 172.31.254.13 42 ms 41 ms 41 ms
3 172.31.22.2 41 ms 42 ms 41 ms
Switch #2 name snj-xm0-nsw010
snj-xm0-nsw010.11 # sh vlan
Active router
/Total
ent_sp0-int001 3151 209.249.151.251/24 ---------------------V------- ANY 1 /2 VR-Default
Mgmt 4095 10.22.211.30 /24 ----------------------------- ANY 1 /1 VR-Mgmt
snj_si0-bkd022 3155 172.31.22.2 /24 -f-------------------l------- ANY 2 /2 VR-Default
snj-xm0-nsw010.12 # sh ipr
#d 172.31.22.0/24 172.31.22.2 1 U------um--f- snj_si0-bkd022 4d:21h:22m:22s
#s 172.31.55.0/24 172.31.22.251 1 UG---S-um--f- snj_si0-bkd022 4d:21h:21m:17s
#d 192.168.0.1/32 192.168.0.1 1 U------um--f- lpbk 4d:20h:16m:7s
#d 209.249.151.0/24 209.249.151.251 1 U------um--f- ent_sp0-int001 4d:22h:38m:46s
snj-xm0-nsw010.13 # sh conf mpls
configure mpls lsr-id 172.31.22.2
enable mpls
configure l2vpn vpls ldc-snj-vpn add peer 172.31.55.2 core full-mesh
snj-xm0-nsw010.14 # sh vpls detail
Source Address : 172.31.22.2 Oper State : Enabled
Created By : CLI
Peer IP: 172.31.55.2
PW Index : 10002
PW Signaling : LDP
Send Next Pkt : --
snj-xm0-nsw010.15 # traceroute 172.31.55.2
traceroute to 172.31.55.2, 30 hops max
1 172.31.22.251 2 ms 1 ms 6 ms
2 172.31.254.45 42 ms 42 ms 42 ms
3 172.31.55.2 42 ms 42 ms 41 ms
20 REPLIES 20
snj-xm0-nsw010.2 # show mpls ldp peer
IP Address LDP Peer State Uptime Adjacencies
172.31.22.2 172.31.55.2:0 Operational 0d:22h:15m:26s 1
ldc-xm0-nsw012.4 # show mpls ldp peer
172.31.55.2 172.31.22.2:0 Operational 0d:22h:16m:2s 1
Both switches are running ExtremeXOS version 15.7.1.4 v1571b4-patch1-2
