I need some help with a Extreme Summit X440-24t configuration
Alysson_Campos
Hi guys, I need some help.
We bought a Extreme Summit X440-24t switch and the idea is to replace a Cisco 3560 switch. I have no experience with XOS and there are two port configurations that I don´t know how to set up. These are the configurations on the cisco way:
## On these port how can I set up the port-security with MAC on ExtremeXOS
1. interface GigabitEthernet0/1:
switchport access vlan 450
switchport port-security mac-address c0ea.e46a.1821
## On these port how can I set up the port to L3 routing port and set up an IP to the port.
2. interface GigabitEthernet0/26:
no switchport
ip address 177.69.10.4 255.255.255.0
i appreciate your help!
15 REPLIES 15
Hello,i gave ip address 192.168.10.x /24 in my pc and in putty i gave 192.168.10.x i was able to login the putty but getting network fatal error.
Please help on this,Thanks in advance.
Hi Ram, I connected console cable laptop and switch and gave ip address in putty and same in laptop to but no use,can u pls help me on this.
Thanks in advance
Connect the console cable into Extreme switch and other end into your laptop. Now open the putty session and select the connection type "Serial", then click "Open". Now you will have access to Extreme switch, enter using username "admin" and password blank (no password).
Tripathy__Priya
Hope the provided information helped you for fetching information which you were looking for. Please let us know if you have any further queries or shall we close this discussion moving forward.....
Tripathy__Priya
In addition to what Bin provided you can also have look at the below article for more info:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-limit-the-number-of-MAC-addresses-l...
