Inter-VLAN Routing not working correctly
IT-SA
Hello!
I just took over a System Administrator role for a company and trying to figure out what happened to one of their VLANs.
I am new to the Extreme Network devices. They currently have 3 stacked X450-e as their main switch stack/router.
The previous SA setup a new VLAN (VLAN11) to free up some IPs on the main subnet.
Some PCs started dropping from the network last week and we ended up figuring out that the VLAN had been removed from the switch configuration.
I readded it and tried to set everything up as it should be but its not working and I am starting to bang my head against the wall and need some other eyes on this to tell me where the issue might be.
I've gone through all the help guides on here and cannot get a PC to ping another PC on VLAN11 from VLAN1. I cannot even get VLAN11 to pass DHCP to the PC. Static set IP doesn't work either.
DHCP server IP is 192.168.0.17
Here is my current switch config:
51 REPLIES 51
Eric_Burke
New Contributor III
Sorry about that - misread the configs (those ipforwarding commands hide in the middle of a bunch of stuff). Let me re-read ļ™‚...
Eric_Burke
New Contributor III
What's routing between VLAN's? I see all of your VLAN's, but I don't see anything routing between them. Do you have a firewall or some other device in place?
