Inter-VLAN Routing not working correctly
IT-SA
Hello!
I just took over a System Administrator role for a company and trying to figure out what happened to one of their VLANs.
I am new to the Extreme Network devices. They currently have 3 stacked X450-e as their main switch stack/router.
The previous SA setup a new VLAN (VLAN11) to free up some IPs on the main subnet.
Some PCs started dropping from the network last week and we ended up figuring out that the VLAN had been removed from the switch configuration.
I readded it and tried to set everything up as it should be but its not working and I am starting to bang my head against the wall and need some other eyes on this to tell me where the issue might be.
I've gone through all the help guides on here and cannot get a PC to ping another PC on VLAN11 from VLAN1. I cannot even get VLAN11 to pass DHCP to the PC. Static set IP doesn't work either.
DHCP server IP is 192.168.0.17
Here is my current switch config:
51 REPLIES 51
I was thinking that too initially. If you static two devices on V11, can they ping eachother?
Robert_Cummins
169.254.0.0/16 are IPv4 link-local addresses that are assigned when a DHCP client does not get a DHCP response.
Robert_Cummins
Other than not supporting IPv6 forwarding vlan11 looks okay.
Are the PCs on the default VLAN able to ping systems on the voice or replication vlans? Can systems on voice/replication reach machines on vlan11? I never configure VLAN 1 so I don't know if it is a good practice do what you're doing here.
Yes, the PCs on default VLAN can ping other devices on other VLANs. I did not create this mess lol.
IT-SA
I should mention that ports 1:41 and 2:30 are currently working. I thought I had it figured out last week but all the other ports I try to enable as VLAN11 seems to fail to pull DHCP IP.
I can ping them from a VLAN1 PC too.
