Is it possible to connect 10 G DAC cable to the X460-G2 Front Panel ports for stacking?
Niyas
New Contributor III
Hi Team,
we have two extreme X-460 core switches, is it possible to connect 2 core switches with 10G DAC cable through the front panel for stacking?
5 REPLIES 5
StephanH
Valued Contributor III
Hello Niyas,
If you have an 10G switch like X460-G2-48t-10GE4 yes. The alternate stacking ports are 51,52 on the front. You will find such kind of information's for all switches in the EXOS user guide easily.
It will be very helpful if you post the exact switch types. Only in this way we can give you correct information's!
Best regards
Stephan
Regards Stephan
